99 dakota 318 idling issues
Old Sep 14, 2010 | 02:51 PM
winter ride's Avatar
winter ride
Default 99 dakota 318 idling issues
while in park idle will go up and down from idle up about 500 to 800 rpms back down to idle
check engine light does come on, but i first noticed this while on the highway rpm's would go up and down. thanks
Old Sep 14, 2010 | 04:41 PM
dodgeramguy85's Avatar
dodgeramguy85
Could be tps. When the one in our jeep was going if you were doing a steady speed it would cut out then rpms would come back up and cel would come on. There is a easy way to test it if you have a meter
Old Sep 14, 2010 | 10:46 PM
magnethead's Avatar
magnethead
agreed
Old Sep 15, 2010 | 11:26 AM
Derek2002's Avatar
Derek2002
Check Your IAC.
Old Sep 16, 2010 | 02:42 PM
winter ride
this might change your thoughts or confirm them. when engine is cold if i just start up and go the truck will buck , sputer and kinda back fire for about 1 mile then runs good, except for the idle.. thanks
Old Sep 16, 2010 | 04:34 PM
corpusfisherman's Avatar
corpusfisherman
and of course don't forget to check/replace that crankshaft position sensor....
