What is wrong with my truck? :video
Old Oct 1, 2010 | 11:31 AM
rgeneral01's Avatar
rgeneral01
Exclamation What is wrong with my truck? :video
http://www.youtube.com/watch?v=FTqQ2PxTyXo
Runs good until it warms up. Then I can't accelerate, rpms bounce around when off the throtle, etc. Then it seems to get a little better, but not good. Replaced the coil, tps, air-temp charge sensor. Cap, rotor, plugs, wires are all good. Not showing any engine codes either. Really appreciate all help!
1999 Dakota 4x4 5.2L Automatic
Old Oct 1, 2010 | 05:16 PM
#DodgeFan#'s Avatar
#DodgeFan#
why does it look like you're in neutral? and your oil pressure seems a bit high
that is weird though, you floored it and it didnt accelerate at all
Old Oct 1, 2010 | 07:24 PM
UWAdventurer's Avatar
UWAdventurer
Bad TPS? My daughter had something similar happen on her way to Virgina on the highway. I think that was the problem. Someone better than me can probably answer this though.
Good luck.
Old Oct 1, 2010 | 08:15 PM
McNasy's Avatar
McNasy
i does show it is in nuetral doesnt it? weird. my oil pressure reads like that if im not idling. he does show a speed increase of about 7mph while he is going. i would almost think tps as well.
Old Oct 1, 2010 | 09:44 PM
#DodgeFan#'s Avatar
#DodgeFan#
yeah i was watching my oil pressure on my way home and it is right up there too, not as high as this one but above half way
Old Oct 2, 2010 | 01:18 PM
rgeneral01's Avatar
rgeneral01
I replaced my TPS last week. It helped with my shifting problems, but not issue that you can see in the video. I am being told on another forum that it is a bad O2 sensor or a bad coolant temp sensor...but it just seems that everyone is guessing. I was hoping to find somebody that has had this problem and solved it. Thanks for taking the time to help me guys!
Old Oct 2, 2010 | 01:19 PM
rgeneral01's Avatar
rgeneral01
I looks like neutral, but it's really drive. The gear selector is off on my truck.
Old Oct 2, 2010 | 01:24 PM
thunder98110's Avatar
thunder98110
in your vid it looks like the gear selector was in N.
Old Oct 4, 2010 | 01:50 AM
rgeneral01's Avatar
rgeneral01
The gear selector is off. It is really in drive, but looks like N. I don't get why I am throwing a P0132 code today and not yesterday. Yesterday I unhooked the upstream O2 sensor and went for a drive...it threw a code (didn't check it)....hooked it back up, disconnected the battery....today I unhook the coolant temp sensor and spray it with electronic cleaner and hook it back up, i also spray some other random sensors that I see.....start it back up and 5 min. later I throw the P0132 High voltage bank 1 code....I unhooked the battery again and it still came back. What does that tell you guys?
Old Oct 4, 2010 | 03:48 AM
oxygen454's Avatar
oxygen454
I found some interesting info on the forum, its a different engine but similar problem, loosing power on acceleration ... https://dodgeforum.com/forum/general...ensor-one.html
More info here http://www.obd-codes.com/p0132
Either way sounds like a O2 is failing.
Might help out...
