reading codes.. whose better to perform task ?
Old Oct 7, 2010 | 05:26 PM
Schuey's Avatar
Schuey
Default is the Autozone obd scanner any different then a dealer obd scanner ie more options ?
would a autozone or pepboys obd scanner be the same thing a dealer would use ? or would the dealer have a more indepth scanner ? or does it really matter ?
ive never needed to be hooked up to one be4 so a bit clueless on if it matters?
Old Oct 7, 2010 | 09:16 PM
midget-farms's Avatar
midget-farms
You don't need a scanner with the dodge trucks - when the OBD2 computer stores a code you can retrieve it by turning the ignition switch on & off 3 times.
If you have a digital odometer the codes will show up there. If you don't the CEL will flash the code (3 flashes = a 3 then a pause then 4 flashes etc.)
The computer will hapily tell you what is wrong - if it knows - I don't believe any of the scanners do anything besides read& display these same codes.
The dealer has the advantage of years of experience with ambiguous codes - for example - my truck threw a P0442 the other day - It could be any of 20 parts that have failed - the dealer told me to buy a new gas cap - that took care of it.
Old Oct 8, 2010 | 08:58 AM
metalsrfr's Avatar
metalsrfr
yeah the key dance gives the same codes as a scanner will it just doesnt give you a description , but once you pull the code you can go here https://dodgeforum.com/forum/1st-gen...ine-light.html and get what the code is and just so you dont have to search for the link it is located in the sticky labeld FAQ
