2000 Dakota 4.7 Rear Wheel Bearings..
Old Oct 11, 2010 | 12:32 PM
ultramindbrk's Avatar
ultramindbrk
Default 2000 Dakota 4.7 Rear Wheel Bearings..
I need to change out my rear bearings..I have searched and searched and can't seem to figure out how to get the axle out to get to them? There are 4 bolts behind the hub,but they are round except one section is flat. (If that makes sense).. So is this rear end like the Chevy's where I have to drain the fluid out of the rear and remove a C clamp to get the axle out? Anyone know? Help!
Old Oct 15, 2011 | 12:10 PM
cbuchanan112's Avatar
cbuchanan112
Yep, remove the diff cover, inside your axles are connected by 2 c-clips, remove the c-clips and your axles will pull right out.!!!
