need help on radiator drain-plug
Old Oct 12, 2010 | 05:21 PM
quyenc2000's Avatar
quyenc2000
Default need help on radiator drain-plug
Do I need to remove the drain-plug completely to drain the radiator? I can only turn the drain-plug 1/4 turn in either direction and no coolant coming out. There seems to be something inside to prevent it from turning more. I also try to pull on it with my hand and it doesn't seem to come out. Any help will be greatly appreciated.
Old Oct 27, 2010 | 11:42 AM
Crazy4x4RT's Avatar
Crazy4x4RT
No you don't have to remove the plug completely. It is best though. Try some WD-40.
Old Feb 12, 2011 | 08:07 PM
UWAdventurer's Avatar
UWAdventurer
You don't have to remove it completely, but it can be removed. Seems like it had to be lined up correctly to remove it. Sorry I can't be more descriptive, but it has been a while since I have had to drain my truck. I was glad I did take it out completely because there are spots for two O rings and mine only had one on it. I added a second O ring to mine. I assume the second O ring is functional.
