Rear Transmission Seal
Old Oct 17, 2010 | 08:46 PM
mfrei's Avatar
mfrei
Default Rear Transmission Seal
Gotta 99 Dakota Sport, 5-speed manual, 3.9 v6. The rear seal on the transmission is leaking. Anyone ever changed one? Is it hard? I found a 2000 Factory Service manual and it looks like I just have to remove the u-joint, pull out the propeller shaft, and pry the seal out (with a special tool of course).
Any suggestions or words of wisdom would be greatly appreciated.
Old Oct 22, 2010 | 10:47 PM
nx2000det's Avatar
nx2000det
Im new,
can you answer these for me?
is there a way to adjust the clutch play any?
im thinking my trans is worn out and the sycnronizers are going out.
and can you tell me the code for the trans?
