T-Bars After Awhile
Old Oct 25, 2010 | 07:21 PM
Mr02kota's Avatar
Mr02kota
Question T-Bars After Awhile
Hey. If i crank my t-bars to get about 2 inches on my 02 QC 4x4, do i have to re crank them after a certain amount of time? or should i just replace the torsion keys with lift keys? What is the best way to lift the front? I know i can add a leaf or 2 to the back.
Old Oct 25, 2010 | 09:07 PM
a-hall's Avatar
a-hall
Keys are a waste of money.The front end will only drop so much before it hits the bumpstops.I have had my tbars cranked 1.5" for about 3 years now with no problems. When you do crank them make sure you go get a front end alingment to make sure everything is good to go. And no after time they shouldnt sag unless you wheel it super hard.
Old Oct 25, 2010 | 11:50 PM
Mr02kota's Avatar
Mr02kota
cool. sounds good. i need an alignment anyways so ill do that right before i go get it done
Old Oct 26, 2010 | 03:48 PM
outlawfox13's Avatar
outlawfox13
I have mine maxed out, and a 3" block under the leafs. It does change the handeling, but I like the feel, I have had it lifted this way for 2+ years.
Old Jan 20, 2011 | 11:20 PM
97Dakota4X4's Avatar
97Dakota4X4
hey outlaw, how is your set up? where did you get your new keys and blocks?
Old Jan 21, 2011 | 12:06 AM
dodgeramguy85's Avatar
dodgeramguy85
I have mine cranked and It looks better than what it did. When I put my truck on the rack the alignment was off a little but not much. Its def worth the time and being able to fit bigger tires is a bonus too.
