Temperture Control
Old Nov 19, 2010 | 07:01 PM
drifter58's Avatar
drifter58
Default Temperture Control
i have a problem with my heat in my dakota, i'm not quite sure what my thermostat temp is but it takes for ever for some decent heat to get into the cab, i even have a piece of cardboard in front of my radiator and that still doesn't help much, my question for you guys is what is the highest/safest temp thermostat i can run in my 3.9 v6, also is there anything else i should look at that may be cause the no heat issue?
BTW, the engine itself warms up just fine, just takes a little bit and its runs in the 160-180 degree range.
Old Nov 20, 2010 | 05:35 PM
1986JEEP's Avatar
1986JEEP
did you fulsh the heater core
Old Nov 20, 2010 | 08:05 PM
thunder98110's Avatar
thunder98110
take off the clutch fan and put on an efan. i get heat within 1 mile of driving.
