Adapters
Old Nov 23, 2010 | 10:01 PM
Danny52186's Avatar
Danny52186
Default Adapters
00 Dakota 15'' Stock Wheels 6x4.5 Bolt Pattern... Rims Are 17'' Bullitts 5X4.5 Bolt Pattern.... Question is Are These The Correct Adapters I Need. Also The Thickness How Many Inches Is Correct Would I Need 1'' or 2'' or Above? The Stock Wheel Backspacing is 5'' If I Measured It Correct
http://cgi.ebay.com/ebaymotors/WHEEL...mZ300485709249
Old Nov 25, 2010 | 10:45 AM
brentfitz3's Avatar
brentfitz3
I'm also looking for adapters right now so I learned some info. The bolt pattern is right for the rims your going to put on. But I'm pretty sure the stock wheel backspace is 5.5, not positive but that's what I measured and read somewhere. And I think if you got the 1 inch you would have to cut the end of your wheel studs a little so I would probably go with the 2"
