01 front suspension, NEED HELP PLZ
Old Nov 24, 2010 | 04:24 PM
thackdak's Avatar
thackdak
Default 01 front suspension, NEED HELP PLZ
i replaced the cv axle boots and completely removed the front differential. when I put everything back in, it seemed fine. 20 miles later, i notice that the right axle is rubbing the bump stop bracket on the frame where the big end of the boot is. I have 2 bolts in the top bracket and 2 on the passenger side bracket and can't get the rear bracket to allign for the bolts. when i try to make it line up it makes the axle rub even worse. I HAVE NO IDEA WHAT IS WRONG AND I CAN'T MISS MORE WORK.
PLEASE HELP
