Timing issue
Old Dec 2, 2010 | 07:45 PM
Henric's Avatar
Henric
Default Timing issue
I am changing the timing belt and sprockets on my '97 Dakota 3.9L because the teeth are all torn up and the chain literally slid off. I noticed its off 180 degrees. However the Rotor is pointing at the number one. How do I turn it so the sprockets are aligned?
Old Dec 16, 2010 | 01:12 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Are you sure it is belt? It's a chain. The crankcase has a bolt in the center of it, so does the camshaft. Make sure you remove the rockers first, if not you can bend some valves as you rotate it.
