whats + and whats - hooking up speakers
Old Dec 29, 2010 | 05:09 PM
Keithpwns's Avatar
Keithpwns
Question whats + and whats - hooking up speakers
i have a 97 dodge dakota i am putting new speakers all the way around. I took out the driver side speaker and disconnected the speaker wires the speaker wires are white with blue stripe and white with pink/purple stripe. what wire is positive and negative?
Old Dec 31, 2010 | 02:16 AM
Crazy4x4RT's Avatar
Crazy4x4RT
I will move this to the 2nd Generation Dakota Sub Forum. There is the service manual there with wiring diagrams.
Old Jan 10, 2011 | 06:14 PM
parky07's Avatar
parky07
Grab a multimeter, if you dont have one go buy one then bring it back after your done. turn on the radio and touch the leads to the wires, you might have to turn the volume up a bit. if you get a negative voltage your backwards, if you get a positive voltage you have to correct pos neg wires.
Or google a wiring schematic for your truck
Old Jan 11, 2011 | 11:08 PM
oxygen454's Avatar
oxygen454
According to the manual...
Dark blue/ white is right rear speaker - Positive
As for the white with pink/purple stripe - could not find in the manual Im guessing... ground?
Like parky07 said... try the multimeter.
