new guy with an engine issue
Old Jan 5, 2011 | 09:07 PM
shanondacanon's Avatar
shanondacanon
Default new guy with an engine issue
Engine runs fine at speed, smooth. When I push in clutch and slow down for a turn or stop, the engine will idle down and then cut out completely. I usually restart with a compression start so I can quickly get power steering back, it will start right away with the ignition also. One time after restart, and only one time, it ran very rough for a short period, 30 seconds, and smoothed back out. It logged a code which said intermittent loss of crankshaft position sensor or camshaft position sensor. I don't want to start changing parts just to change parts. Can anyone point me in the right direction? 99 Dodge Dakota, 4x4, 144K miles, 5.2L, 5 sp. manual. Thank you.
The only new cars I have ever bought were both Dodges, this one and a 1984 Dodge Omni GLH. Man do I miss that car, what a pocket rocket!
Old Jan 6, 2011 | 07:44 AM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. I will move this thread to the second generation Dakota section,
FF
Old Jan 6, 2011 | 10:39 AM
corpusfisherman's Avatar
corpusfisherman
I understand about hating to throw parts at a problemo, but the crankshaft position sensor is a notorious issue with these trucks. I know, I had mine go out. I didn't believe the code reader and cleaned all kinds of parts and wasted a bunch of time before finally biting the bullet and changing the sensor. two bolts and a snap connector near the distributor. 20 minutes later, and I haven't had a problem in 6 months now. that was the fix.
