Computer codes
Old Jan 9, 2011 | 02:44 PM
Jensen 7000's Avatar
Jensen 7000
Default Computer codes
Hi again have a good one here need help. I looked at a 2001 dodge dakota guy wants to trade me when i test drove it it drove fine everything seem to work great check engine lite on codes po455 po302 po442 day later he calls said no more codes said he changed spark plug while back and forgot to pull pos cable to battery to clear there is no way to fool computer is there if codes are gone its really been fixed. Thanks for your time.
Old Jan 9, 2011 | 04:54 PM
dodgeramguy85's Avatar
dodgeramguy85
The 445 and 442 is most likely a just a vacuum leak so its not a big deal and the 302 might just be a bad plug or wire. Just test drive it again and see if it comes back on.
Old Jan 9, 2011 | 04:55 PM
metalsrfr's Avatar
metalsrfr
not always my check engine light isnt on but i still has an o2 sensor code on it , what you can do is turn the key to the on position do not start the truck then turn it off , and turn it on again and off once again not starting then turn on for the 3rd time and leave it on and it will show whatever codes there are in the odometer window and it will say pdone when finished. now if he disconnected the battery it will clear the codes and it wil take the truck the about 5 cycles to bring the codes back up if there is a problem.
You can see what the codes are here https://dodgeforum.com/forum/1st-gen...ine-light.html They are located at the top of the forum in the diy sticky incase you need to find them again.
Old Jan 9, 2011 | 05:12 PM
Jensen 7000
Default Thanks for the advise guys.
So if someone is playin games if I drive the truck and turn it of and drive and turn it off a few times if he didnt fix it codes will come back up. I agree the codes arnt terrible Im sure I could fix.
Old Jan 9, 2011 | 05:23 PM
Pwall's Avatar
Pwall
yes if he didn't fix the issue the light should come back on it depends on how you drive and the conditions to trigger it to come on and i may be mistaken but the fault that would produce the code has to happen on three different drive cycles
Old Jan 9, 2011 | 05:45 PM
Jensen 7000
Default Thanks again
Thanks for your help like I say doesnt sound like the codes are that bad Im sure I could fix.
