thermostat housing still leaking
Old Jan 11, 2011 | 03:18 PM
hypersmurf's Avatar
hypersmurf
Default thermostat housing still leaking
i have a 2000 dakota sport 4.7L V8, i have replaced the t-stat and housing, but still leaks i have tryed the gasket in a tube and a cork gasket, neither one worked, going to try a silicone gasket maker. any advice?
Old Jan 11, 2011 | 06:00 PM
cowboy63645's Avatar
cowboy63645
Have you checked the housing to make sure it isnt cracked?
Old Jan 11, 2011 | 09:02 PM
hypersmurf's Avatar
hypersmurf
Default ...
i have, i just recently replaced the housing because it was cracked, i am going to put silocone gasket maker on it in the mornig and hopefully that will stop the leak, if not do you have any other suggestions
Old Jan 11, 2011 | 09:11 PM
96magnumram's Avatar
96magnumram
did you not get a fiber or rubber gasket for it? There should be one there and you RTV it to the housing itself. The thermostat gasket part number at Autozone is 35692.
Old Jan 11, 2011 | 09:22 PM
hypersmurf's Avatar
hypersmurf
i was givin a little tube that said thermostat gasket on it, im not sure what kind of gasket it was
Old Jan 11, 2011 | 09:24 PM
dodgeramguy85's Avatar
dodgeramguy85
Just get rtv gasket maker its like 7.00 at autoparts store thats what I used on mine and you sure the housing is leaking and not the hose connected to it?
Old Jan 11, 2011 | 09:27 PM
hypersmurf's Avatar
hypersmurf
Default ...
im not 100% sure that its not the hose as well but i am sure that the housing is still leaking
