another "will it fit" question
Old Jan 11, 2011 | 10:52 PM
rewster's Avatar
rewster
Default another "will it fit" question
I have an 01 Dak C/C 4x4 and I am trying to make sure this set up will work with minimal issues. I have cranked my TB 5 full turns up front and put 2" blocks on back. The truck is about 3/4" away from level and now its time to figure out the tires that will fit. I have access to a set of great condition 285/75 16's and they look like they will fit in and I can use the heat gun/spoon method to get a bit more clearance at full lock. Maybe just touching at full lock but still do-able. Has anyone tried THIS setup. I know it would clear if I added a 3" Body lift but i don't offroad except pulling my wife out of a ditch from time to time, so the BL is out. But I just wanna know ASAP if anyone has gone this route and has advice. Also backspacing an issue?? any other thoughts are welcome. Thanks fellas.
Old Jan 12, 2011 | 12:23 AM
dodgeramguy85's Avatar
dodgeramguy85
Might be close I think thats a little bigger than a 32 Really height isnt too much of a issue its the width. I have my tb cranked to where is level with my rear and I have 32/1150/15's and they only rub a little under full lock. Btw you will need a alignment also if you just recently had one it wont be too bad but I had mine done 5,000 miles before I cranked mine so when I checked it was off a little
Old Jan 12, 2011 | 12:43 AM
rewster's Avatar
rewster
Yeah I just cranked the bars and was making a decision on tires by the weekend so I'll align them at that point. The 285/75 breaks down to 32.8 by 11.6 so if yours basically cleared mine should to. Got any photos of the way yours looks now? Just to plan ahead
Old Jan 12, 2011 | 12:59 AM
dodgeramguy85
Here is thread that I started there is a few pics threw out and some tire talk in there also
https://dodgeforum.com/forum/2nd-gen...-winter-8.html
Here are a few other pics
I do have to get better day pics I just took these cause I put hid fogs in they came out kinda blurry
Old Jan 12, 2011 | 01:56 AM
rewster's Avatar
rewster
That's exactly the look I'm wanting. Outstanding! Thanks.
Old Jan 12, 2011 | 02:11 AM
dodgeramguy85
Yeah no problem
