Check Engine Lights does not light at start
Old Jan 14, 2011 | 03:07 PM
tomgregorski's Avatar
tomgregorski
Default Check Engine Lights does not light at start
My Check Engine Light (MIL) does not come on when I turn the key on (test cycle). Does this mean that the Instrument Cluster circuit board is bad? The manual says this light is a LED that is part of the circuit board and I assume the light test function is also part of the circuit board. Does anybody have any experience with this? I can't pass inspection because it sees this light failure.
Old Jan 14, 2011 | 03:33 PM
sonderegger's Avatar
sonderegger
on my 99 its just a bulb with a socket. most likely ur bulb is burnt out. pull the cluster out and check it
Old Jan 14, 2011 | 09:25 PM
Derek2002's Avatar
Derek2002
If you hold the trip button while you turn on the key your gauges will go through a full test cycle.Try that and if it still doesn't illuminate then I would say the bulb is just burnt out.
