Question on changing transmission fluid...
Jan 16, 2011 | 09:13 PM
From: Live: Silverdale, WA; Work: WA, CA, VA, GA, FL; From: WV
Question. Which is better?
1. Typical pull off pan, drain, replace screen, reassemble, fill up again...
2. Have the service done that completely changes out all the fluid. They remove it all by suction and replace it...
Jan 16, 2011 | 09:18 PM
i called a local trans shop and asked the same thing. they said to just drop the pan. if you do the full flush it can slipping.
remember atf+4 only
Jan 16, 2011 | 09:42 PM
What about the Valvoline MaxLife DEX/MERC ATF? It's synthetic and supposed to be good for just about everything...
Jan 16, 2011 | 09:46 PM
everything i heard is only, only atf+4. the mopar stuff is synth anyways.
Jan 16, 2011 | 09:49 PM
