replaced trottle body
Old Jan 26, 2011 | 07:46 PM
ff69's Avatar
ff69
Default replaced trottle body
I replaced my trottle body today with one the that i modified, i milled down the surface .90 removing the air horns in process bored out to two inches and chamfered, sand blasted the side and poilshed bores and sufaces and butterflys i also replaced the seal ball bearings. I have the idle set at 500 rpm's it seams a little senstive i am going to run it for awile to see how it does then fine tune it back to 630 rpms but it seems to run fine i have notice the increase in respones . i plan to mod the one i took off and sale, i wil post a add when it is ready. thanks
Old Jan 26, 2011 | 07:53 PM
thunder98110's Avatar
thunder98110
500 may be a little low, you might have charging issues. thats what my tuner sean powell told me. have any pics?
Old Jan 26, 2011 | 08:14 PM
ff69's Avatar
ff69
no pics yet, i will get sum togetter. thanks
Old Jan 28, 2011 | 10:29 AM
Blaze10's Avatar
Blaze10
i am interested in seeing myself.
Old Jan 28, 2011 | 01:42 PM
DakMan6704's Avatar
DakMan6704
I found a bunch of TBs near me...now to decide if I want to pick them up!
Old Jan 28, 2011 | 05:43 PM
ff69's Avatar
ff69
the two that were mod, one is on my truck and the other i traded at work i plan to start two more on monday then i will post some pic, i did adjust the idle to 600 rpm'severy thing is running good, i am all so useing seafoam to clean out the engine. thanks
Old Jan 28, 2011 | 11:29 PM
Blaze10's Avatar
Blaze10
i used this bg **** that they only sell at dealerships and they hook it up to a compressor and blow that **** down in there, eats carbon within seconds.
