How to replace front CV joint on propeller shaft?
Old Feb 4, 2011 | 03:14 PM
dbilik's Avatar
dbilik
Smile How to replace front CV joint on propeller shaft?
Doing my transfer case motor replacement and I noticed that the CV joint boot on the front of the propeller shaft is gone and the joint was filled with water. Checked the FSM, couldn't find a repair procedure for this joint. NAPA sells them, but can anyone tell me what I need to do to replace it? Or where to find the repair procedure? Thanks.
Old Feb 4, 2011 | 03:18 PM
thunder98110's Avatar
thunder98110
just buy a new drive shaft with ujoints on both ends. not sure if you can replace the CV. new drive shafts run 250 on ebay.
