wont start
Old Feb 21, 2011 | 11:08 AM
Jmageee902004's Avatar
Jmageee902004
Default wont start
So i just got back from a trip to Kansas. when i was gone i had a guy put in a new water pump in the truck, because the old one broke and ended up covering my engine compartment in coolant. anyways when i got in the truck to start it, it took about 3 seconds for the starter to crank the engine before it started up then no problems. when i parked it and tried to start it again 15seconds later, the starter just cranks the engine but it wont start. the starter is getting plenty of power and works fine.the engine just wont start. I thought it might be because its 15degrees out here in MN, but then why would it start the first time? could the coolant being sprayed all over the compartment have anything to do with it? some got on my passenger side exhaust manifold and smokes ( i wonder if i got somewhere else?). any suggestions would be of great help
Thanks
Jim
Old Feb 21, 2011 | 11:09 AM
Jmageee902004
Default wont start
and its a 98 V6 4x4 165,000miles auto transmission, and a v8 throttle body
Old Feb 21, 2011 | 12:10 PM
cowboy63645's Avatar
cowboy63645
Have you tried to disconnect the battery to reset the computer? Also, is it throwing any codes?
Old Feb 21, 2011 | 05:25 PM
Jmageee902004
Default wont start
Not throwing any codes, and il try to reset the computer tonight.
Old Feb 21, 2011 | 06:56 PM
Jmageee902004
Default wont start
havent tried the battery yet, but it did it again where it started up on first crank after about 4 hours of just sitting, ran for about 5mins then shut it off and tried to restart it again, and it wont go. i tried "priming" the fuel pump by turning it on waiting for a few seconds then starting it but it did nothing
Old Feb 21, 2011 | 06:58 PM
Jmageee902004
could the guy installing the water pump have screwed something up at all? he wasnt a perfessional
Old Feb 21, 2011 | 09:20 PM
UWAdventurer's Avatar
UWAdventurer
Moisture in your distributor cap?
