Losing Coolant
Old Mar 3, 2011 | 10:51 PM
jrossjr79's Avatar
jrossjr79
Default Losing Coolant
Ok, I am losing coolant right at my thermostat housing. So far I replaced the bottom hose as well as the clamp. Replaced the thermostat itself. While I was changing out the thermostat I looked over the housing. The plastic piece that connects to the hose and the metal part of the housing. Neither of which has any cracks, hose is on there right. I didnt see any signs of a seal, nor did I see that it was called for. So question is, should I take the housing off again and use RTV sealant to seal it?
Would this cause any problems, would it fix my problem, or do I need to do something else.
Please help, thanks.
Old Mar 4, 2011 | 12:37 AM
dodgeramguy85's Avatar
dodgeramguy85
On the bottom of the housing there is supposed to be a gasket I just use rtv on it and it seals fine.
Old Mar 6, 2011 | 03:51 PM
jrossjr79's Avatar
jrossjr79
Ok, I just put some RTV on the housing, hopefully it will work, will keep yall updated.
Thanks
Old Mar 7, 2011 | 08:48 PM
jrossjr79's Avatar
jrossjr79
Well currently I am at a lost, yesterday it seemed to be holding just fine, however today it seems like it is leaking more today than it has before.
Old Mar 7, 2011 | 08:57 PM
Cert88's Avatar
Cert88
I had the same problem shortly after I bought my durango. I replaced the gasket and it hasnt leaked since.
Old Mar 7, 2011 | 09:06 PM
jrossjr79's Avatar
jrossjr79
Ya, I just added RTV gasket, and it did no good
