blower motor
Old Mar 6, 2011 | 12:15 PM
sleepingiant's Avatar
sleepingiant
Default blower motor
thanks for the help on this matter. i changed out the blower motor resistor and still have low med med2 and when i put on high it seems to blow at low speed(did the same with old resistor) could it be a 3 spreed fan that may have been put in or is the fan going or
second could it be the control on the heater console
Old Mar 6, 2011 | 07:14 PM
BAMF1500's Avatar
BAMF1500
Probably the switch. If the resistor went bad it will usually only blow on high.
Old Mar 7, 2011 | 09:26 AM
JBs DAK's Avatar
JBs DAK
My bet is the switch.
Old Mar 7, 2011 | 02:13 PM
mazz3242's Avatar
mazz3242
i literally just changed mine after two years of having only high, make sure when you put it in its not on an angel, i don't know why but what happened to yours happen to mine
Old Mar 8, 2011 | 12:26 PM
sleepingiant
Thanks to all for the help. Unfortunately where I live the dodge dealer says that that switch is part of the cluster including vent control and hot/cold and is not separate. As well my haines manual is sketchy on reoving the cover so that I could at least test it with a meter and the dealer was of no help
