Bearing of AC clutch problem
2003 Dakota SXT V6
After the serpentine belt and tensioner were replaced the bearing on the AC compressor has started squealing (badly) if I spray Teflon lube into the compressor clutch area it quietens for a while.
AC works fine, running the compressor doesn't change the noise.
It is possible to replace only the front bearing assembly? The complete compressor unit is expensive..
Thanks
Thanks
