shackle lit help needed
Old Mar 13, 2011 | 05:48 PM
willyb8's Avatar
willyb8
Default shackle lit help needed
ok so one of my shackles broke and started to go through the bed. so i figured i'd get new ones that lift it up, why not right. i've heard the 2wd ones lift it up some on 4wd models. how much will the stock 2wd ones lift it up? if i get some 2wd lowering shackles will that lift it up more? summit has some 2in drop ones for 2wd. how do i figure out how much it will lift a 4wd. i assume if the stock ones lift it say 1in. then the 2 in drop ones should lift it 3in correct. or is it cut in half because i'm only lifting one side of the spring? i'm confusing myself. if the ones from summit wont work can someone recommed somewhere to get some.
http://www.summitracing.com/parts/DJM-SH2397-2/
thanks
Old Mar 13, 2011 | 09:13 PM
frydaddy82's Avatar
frydaddy82
just go to advance and get some lift shackles. there pretty cheap
Old Mar 14, 2011 | 09:33 AM
willyb8's Avatar
willyb8
they have them? really. i'll call them, thanks. are they actually lift shackles for the 4wd or just stock shackles for 2wd models
