2001 Dakota barely running
I have a 2001 Dakota, 2WD, 4.7L V8. It was running fine with no problems. All of a sudden it started missing and running extremely rough. I barely made it home. I had the trouble codes scanned and this is what they gave me
P0300 - Random cylinder misfire
P0301 - Cylinder 1 misfire
P0302 - Cylinder 2 misfire
P0304 - Cylinder 4 misfire
P0355 - Cylinder 5 coil
P0201 - Cylinder 1 injector
P0051 - Oxygen sensor heater
P0132 - Heated oxygen sensor bank 1 sensor 1 high voltage
P0136 - Oxygen sensor
P0138 - Oxygen sensor
P0152 - Oxygen sensor
P0158 - Oxygen sensor bank 2
P0500 - Vehicle speed Sensor
It is barely running, has a strong smell of fuel. Fuel pressure checked out at 50PSI
I pulled all of the spark plugs to get a better idea of what was going on in there and this is what I found
1- wet with fuel
2- wet with fuel
3- wet with fuel
4- dry but black
5- dry but black
6- damp but not soaked
7- damp but not soaked
8- wet with fuel
I am at a loss with this thing so I figured I would stick it on here and see what you guys have to think.
1- wet with fuel
2- wet with fuel
3- wet with fuel
4- dry but black
5- dry but black
8- wet with fuel
