power window not workin
Old Apr 12, 2011 | 08:44 PM
dakoman859's Avatar
dakoman859
Default power window not workin
my power window started acting up it wouldnt go down but if you gave the door a couple cracks it would ease down now it wont work at all i hooked up power to the motor and found out the motor was gone is there anyway the fix the motor or just replace it i heard of people fixing then but i was just wondering
Old Apr 13, 2011 | 01:04 AM
ryan_brown33's Avatar
ryan_brown33
easiest thing to do is replace the whole regulator/motor. this happened to me on new years eve and my window wouldn't stay up. i called around dealerships and parts stores and it turns out the motor by itself is actually more expensive than the motor, regulator, and lifetime warranty all together
Old Apr 13, 2011 | 12:20 PM
dakoman859's Avatar
dakoman859
thanks i figured it would be easier i will have to see if i can find a used one probably be cheaper i got a quad cab do you no wat motors would work its for my drivers door im assuming a durango one would work any others that you no of
Old Apr 13, 2011 | 06:19 PM
ryan_brown33
no none others that i know of. and the risk with used ones is that you run the risk of those breaking very soon and having no warranty. the plastic cable guides on the regulator are infamous for breaking which comes with age. i picked up a new one made by Dorman for like 89 bucks at auto zone, and it comes with a lifetime warranty. but no im not sure if regulators from other vehicles would fit, and yes im assuming it is the same for a durango.
