hood scoop
Old Apr 20, 2011 | 08:18 PM
Pwall's Avatar
Pwall
i would like to do that but i would never have the ***** to cut my hood and i to would put in an extra battery
Old Apr 20, 2011 | 08:25 PM
HammerZ71's Avatar
HammerZ71
Why not? In my case the hood was dented anyway, and you don't have to make a big hole, mine's about 1/4 the size of the scoop. The stick-on scoop more than covers it. The scoop WAS a band aid for the dent, now it's a band aid over the hole.
I used one of them roto-zip type tools, just duck taped my little rectangle to make nice, straight lines to follow.
I do want to get some kinda rubber door/window molding and put in around the edges of the cuts though and pretty it up. It looks like a rough cut hole from the underside. Would look like it came that way with some molding on it. Reckon I'll do that when I invest $5 in PVC to re-route the CAI and get the battery tray and do the 2nd battery. I'm also thinking I need to put something inside the scoop right behind the hole in the hood to direct ALL the air down into my cone filter.
The only thing I'm displeased with is the fact I put the scoop on as soon as I got it to cover the dent, then got the idea to make it functional (and only really contemplated that when I determined I really need a 2nd battery with the winch, all my lights, etc.) so I took it off with fish line and had to scrape the 3m tape off the scoop, took the leftover tape residue off the hood easy enough with a pinstripe wheel.
The 3M tape I bought was thicker than what it came with, so there is a small gap around the scoop, you can see if you're up real close.
I ain't yanking the thing off again and it's not a big enough gap for bondo or anything. Oh well...
Old Apr 20, 2011 | 11:00 PM
brandofamily's Avatar
brandofamily
Originally Posted by thunder98110
found this on ebay for 60 bucks, fiberglass. good workmanship on it. fitment on the hood isnt 100% but its close. just a little work to get it right. it will be functional
got a link?... I might be interested in something like this...
Did it come painted or did you paint it?
Old Apr 21, 2011 | 12:11 AM
thunder98110's Avatar
thunder98110
it came black. go to ebay and type in srt hood scoop or srt8 hood scoop.
Old Apr 21, 2011 | 12:27 AM
ryan_brown33's Avatar
ryan_brown33
thunder you should get a pic of it from the cab im curious to what that looks like man
Old Apr 21, 2011 | 12:29 AM
thunder98110
i will post one up tomorrow. just drove like 200 miles today. tired as hell and plus its dark.
Old Apr 21, 2011 | 12:31 AM
ryan_brown33
cool sounds good man
Old Apr 21, 2011 | 10:09 AM
Josh Abels's Avatar
Josh Abels
Is it off any specific vehicle or r all the srt scoops the same
Old Apr 21, 2011 | 10:39 AM
thunder98110
i think its for rams and 3G daks, but they have some for chargers aswell.
Old Apr 21, 2011 | 11:04 AM
thunder98110
from the inside:
