dodge dakota front bumper help
Old Apr 24, 2011 | 02:59 PM
mattmann92's Avatar
mattmann92
Default dodge dakota front bumper help
i need some help on how to install the front bumper on a 1998 dodge dakota if anyone can help that be awesome thanks
Old Apr 24, 2011 | 03:12 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Welcome to Dodge Forum!! Check out the Dakota section!!
Dusty
Old Apr 24, 2011 | 04:57 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. I will move this thread to the second generation Dakota section,
FF
Old Apr 25, 2011 | 07:29 PM
Yarnie's Avatar
Yarnie
I have a 99, but I figure they are likely the same. There are four brackets mounted directly to the frame of the truck. Taking the old off I am not sure how much help I will be, as we ripped mine off after the wreck...but putting it back on it is easiest to leave the middle two brackets attached to the frame, and the outermost brackets attached to the bumper initially. there will be hight adjustments on both, when you bolt them to the frame (two bolts for each bracket) bolt the middle two down first and get it to the height you want it and get it on there tight. When you go to do the outer two leave them snug, but still enough "play" in it to adjust it, it is easier with help. Have the helper hold one edge of the bumper where you want it while you tighten that side down, then do the same on the other side.
Its been awhile, so sorry if its a bit sketchy, but if you have any questions from there I will answer them best I can.
Old Apr 27, 2011 | 10:29 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
welcome to the site
