ok so ive been researchn a 5.2-5.9 swap and pretty much have every thing figured for what i have to do. the only thing is with the ecu. i keep hearn that the 5.2 ecu will run a 5.9 but when you try and drive it wont run very well. so will i have to swap a 5.9 ecu in or can i get a sct with a tune for this swap?
It will run the 5.9 just fine but you wont be getting the full performance from the 360. Most people temp run them just so they can drive the truck and make sure everything is ok. You can run a 5.2 pcm but dont run it for too long.
