5.2 and Trans Question
Old May 5, 2011 | 05:43 PM
mfpudak's Avatar
mfpudak
Default 5.2 and Trans Question
My 99 5.2L, 5 spd may need a new motor and I've found a used one from a 97 ram auto. I know that they should be the same motor but is there an issue mating the 5 spd to the crank of the new motor if it originally had an auto?
Thanks
Matt
Old May 5, 2011 | 06:43 PM
frydaddy82's Avatar
frydaddy82
you will just need to make sure you got the pressure plat off your old motor and get a new pilot bearin for the new crank
Old May 6, 2011 | 12:31 PM
mfpudak's Avatar
mfpudak
So the new motor's crank will accept the pilot bearing?
