Truck occasionally dies when stopping
Old Jun 1, 2011 | 09:16 PM
  #31
samnbensdad's Avatar
samnbensdad
Any time you replace a faulty TPS, you have to reset the PCM. Otherwise, it will not run right. This is because the PCM is still trying to compensate for the errors it "learned" from the faulty one.
In case you are uncertain, this is how to reset the PCM:
  1. Remove the negative battery cable
  2. Turn your key to the start postion and hold it there for 30 seconds
  3. Remove key
  4. Re-attach negative battery cable
  5. Start truck and let it idle for about 10 seconds (do not touch the gas pedal)
  6. Kill the engine
  7. Start engine again and drive as usual
Old Jun 2, 2011 | 02:20 PM
  #32
tinmanchris's Avatar
tinmanchris
  3. Remove key
  6. Kill the engine
Good to know! I'll do this when I get home today.
Old Jun 3, 2011 | 12:13 PM
  #33
loafer's Avatar
loafer
Sounds like you may have a sticky EGR valve.
Old Jun 3, 2011 | 05:08 PM
  #34
samnbensdad
His truck doesn't have an EGR system. It would be a good idea to change out the pcv valve though. They are about $4.
Also, if it only gives you problem after it warms up, it could be a pre-cat O2 sensor. They don't always throw codes. Btw, this is an item that should only be purchased at the dealer. These engines don't usually work well with other brands.
Old Jun 3, 2011 | 06:11 PM
  #35
McNasy's Avatar
McNasy
X2 on the Egr valve, he beat me to it. we dont have one. haha
Old Jun 3, 2011 | 11:02 PM
  #36
01KotaQuad's Avatar
01KotaQuad
Mine kept doing that and it was the IVAC sensor, $30 easy fix, reset PCM and it worked fine since
Old Jul 18, 2011 | 01:43 PM
  #37
tinmanchris
I'm guessing you mean IAC sensor? :P
Old Jul 18, 2011 | 01:46 PM
  #38
tinmanchris
Sorry been away for a while, recently had a major job change and hadn't have the time to troubleshoot the Dakota. Things are ironing out now and I really want to work on this now as the Dakota is now my daily commuter (ouch on gas).
Another thing I notice is that my truck has been shifting very hard lately. And when it does die coming to a stop, it's almost as if my truck has issue shifting down a gear; like it's trying to lunge to fight against the breaks. Weird eh?
Old Jul 19, 2011 | 01:01 PM
  #39
crateampsrock's Avatar
crateampsrock
Just a thought. Check the ouput of your Alternator. Being that the 4.7L has a 100% electric ignition system, it is very dependant on the output of the alternator. Any low output of the alternator would dampen the ability of the Ignition system to give a sufficiant spark, thus at idle-down could kill the truck.
Old Jul 21, 2011 | 02:50 PM
  #40
tinmanchris
Just found out I'm leaking transmission fluid... it's not too bad but I'm wondering if that has anything to do with it.
