help removing rear leafs.
how do you get at the bolt holding the front of the spring on? i removed the nut and the bolt wont spin. there is a hole on inside of frame rail, are you supposed to drop gas tank to get at it. hoping someone has a trick to help me out. i can cut it off but then how will i get the new one in there?
