'99 3.55 L/S rear end rebuild kit?
Old Jul 8, 2005 | 05:09 PM
Batphreak's Avatar
Batphreak
Default '99 3.55 L/S rear end rebuild kit?
Anyone know where I might find a rebuild kit for the rear? My limited slipness seems to be not so limited anymore, inside tire easily breaks loose on turns and such. So, just wondering if I can replace the little friction clutches or should I go a more expensive route. Any ideas?
Old Jul 11, 2005 | 04:20 PM
Batphreak's Avatar
Batphreak
Default RE: '99 3.55 L/S rear end rebuild kit?
Ok...so I changed the fluid in the rear this weekend. Guess what, found chunks of what probably used to be friction clutch stuck to the magnet. Dealer said I have to buy a whole carrier, anyone run across a rebuild kit? Pretty sure these are Dana units, all the old Danas had rebuild kits fer 'em. I'll post pics of the chunks later if anyone is interested.
Old Jul 12, 2005 | 01:18 AM
horatio102's Avatar
horatio102
It's a Chrysler 9.25 rear end, is it not?
Call up Randy's www.ringpinion.com - they'll set you straight.
Old Jul 12, 2005 | 04:46 PM
Batphreak's Avatar
Batphreak
Sweet action! Called 'em up, they've got the friction clutches in stock, should be all I have to replace. Thanks a lot for the tip horatio!
Old Jul 12, 2005 | 11:30 PM
horatio102's Avatar
horatio102
Good deal. Dealership should be last resort only. [8D]
