remove leaf spring help
Old Jun 17, 2011 | 10:08 PM
thunder98110's Avatar
thunder98110
Default remove leaf spring help
i am planning on removing just the helper spring in the rear, the smallest one on the bottom to lower the dak a few. any tips or tricks? i have my haynes manual. i assume i can just unbolt the ubolts and slide it off. anyone? lol
i found a tutorial on how to do it on dodge talk. pretty cool. i might get r done
Old Jun 18, 2011 | 01:55 AM
MoparMan1991's Avatar
MoparMan1991
Are you just trying to lower it to level it out or something?
Old Jun 18, 2011 | 12:35 PM
01KotaQuad's Avatar
01KotaQuad
Just use a block to lower it....
Old Jun 18, 2011 | 04:28 PM
ryan_brown33's Avatar
ryan_brown33
a block would raise it, hence the name "lift block", since it is a spring over axle and not spring under
