Low vaccuum at idle and running very rich
Old Jun 25, 2011 | 12:52 AM
99-318's Avatar
99-318
Default Low vaccuum at idle and running very rich
So my trucks in the dodge dealer for running ****ty and then ending up stalling, They tell me its running very rich and 14 psi vaccuum or whatever, He tells me he thinks its a broken valve spring, I have noticed my truck smoking a bit blue, Starting to make a bit of sence, What do you guys think? I need to get this thing back on the road.
Old Jun 25, 2011 | 09:01 AM
bwdakrt's Avatar
bwdakrt
Sounds more like a blown belly pan gasket to me. Remove the air hat and use a flashlight to look down inside the intake thru the TB. If you see a lot of oil, the gasket is toast.
Old Jun 25, 2011 | 12:47 PM
99-318's Avatar
99-318
I replaced that gasket about 7 months ago, it is possible it's leaking but I don't loose a crap load of oil, like a quart every 3 -5000 miles. Truck won't even stay running it ends up so rich,
Old Jun 25, 2011 | 03:03 PM
bwdakrt's Avatar
bwdakrt
Anything is possible but it will only take a few minutes to look down inside the intake to be sure.
