Fuel injectors 5.9 upgrade, to 4 hole injectors
Old Jun 27, 2011 | 05:49 PM
divco13's Avatar
divco13
Default 1998 Fuel injectors 5.9 upgrade, to 4 hole injectors
Has anyone swaped single port, to 4 port ( hole ) Bosch Injector's in a 1998- 5.9.
Don,t want after market. Want, stock DCX part or Ford,
What Make, and Model / Year, did you use ?
Want to keep rate of flow the same, just better atomization.
Looked for a conversion chart on line, no luck
__________________
Old Jul 5, 2011 | 10:20 PM
atthewmartin114's Avatar
atthewmartin114
dont bother it wont help just loads up unless you change the computer setting i tried with my 318 even the 19# injectors in the 5.0 make them load up because of the diration its +1.5/-1.5 and the dodges are only 1.25. i spent about 2 hours on the phoine with chrysler in detroit getting specs and setting for them and unless you costom flash and program the filters it wont happen. and be worth it
