Rear speakers in dakota
Old Jul 12, 2005 | 11:57 PM
syllinx's Avatar
syllinx
Default Rear speakers in dakota
Just wondering if there was any factory mounting kit for the back speakers in the wall of the dakota extended cab model. I might be seeing things but theres only 2 holes for screws then 3 bracket things for screws but there is nothing to mount to them.
Old Jul 13, 2005 | 12:41 AM
TexasNative's Avatar
TexasNative
Default RE: Rear speakers in dakota
are u upgrading the speakers??? if u r I put in a set of pioneer speakers in the front and back and they sound awesome just use the supplied mounting rings and u r good to go.
Old Jul 13, 2005 | 01:02 AM
syllinx's Avatar
syllinx
Well they seem ok the previous owners put in pioneer 180 watt speakers but took the mounting stuff so they just hang and vibrate insanely. I just wanna get them mounted firmly with no vibration so i can get the wires worked on. It cuts out if i put bass on and this is the factory tape player. Im thinking the wires may just be crossed but now that i talked to the dealer they say there are not crossed and that the tape player just cant power the speakers so it cuts out back and forth. I hope this is the problem cause they sold me the factory cd player for 50.00 seems good just need to mount the back speakers and see if it cuts out with the cd player.
Old Jul 13, 2005 | 01:43 AM
TexasNative
okay first and foremost 1 word for you DYNOMAT second only an aftermarket(pioneer, kenwood, sony) deck with a small built in AMP can even attempt to push decent aftermarket speakers. Second i think you can goto crutchfield and order the mounting stuff no prob, and you could get the dynomat from them as well or you could goto someplace like bestbuy and get the stuff there.
Old Jul 13, 2005 | 07:10 AM
syllinx's Avatar
syllinx
Thanks for the help. At first it was getting no bass but now it is lol and it onl y cuts out if i try to use all 4 speakers at once but if i switch to the front or back only it seems fine.
Old Jul 14, 2005 | 12:16 AM
TexasNative
still sounds kinda fishy! you might try to go to and audio dealer(aftermarket) and have them trace the wires to make sure you dont have something crossed.
