Bizarre Overheat
Old Aug 2, 2011 | 09:19 PM
Cas161's Avatar
Cas161
Default Bizarre Overheat
I just finished installing a 3" body lift on my 04 Dak V-6.
Install involved removing the upper & lower radiator shrouds and both hoses.
After everything was back together, I filled the radiator with a gallon on A/F that said you could mix with all types. (couldn't get the pink) I didn't flush the system.
After about 10 minutes of driving, the check gauges light came on and the temp gauge was almost in the red.
I just drained and rinsed everything and tomorrow, I'm going to do a full system flush.
Did I eff things up? What could cause this?
Old Aug 2, 2011 | 10:47 PM
tech_support's Avatar
tech_support
could have possibly had a air pocket in the cooling system. Run it with the cap off until the thermostat opens up and no bubbles surface
Old Aug 3, 2011 | 01:07 PM
sl2racer's Avatar
sl2racer
sounds like an air pocket
