Camber adjustment?
Old Aug 9, 2011 | 12:01 PM
00daksport25's Avatar
00daksport25
Default Camber adjustment?
I have a 00 dak sport 2wd and I was looking at my front end the other day and noticed that I have a negative camber. It's not too horrible but I don't want to mess up my tread or anything. Is there a way to adjust the camber on these trucks? Any help would be much appreciated. Thanks.
Old Aug 9, 2011 | 03:17 PM
misfitdakota_95's Avatar
misfitdakota_95
I wouldn't mess with the camber setting unless you have access to a front end alignment machine. With these trucks, if you adjust camber, you will throw off your caster which will cause a pull in your steering wheel. Your best bet, get a 4 wheel alignment from a reputable service facility.
Old Aug 9, 2011 | 04:24 PM
00daksport25
Alright I'll go down to a shop. Thanks for the help.
