How much weight can I tow....
Old Aug 29, 2011 | 03:26 PM
sidhartha's Avatar
sidhartha
Default How much weight can I tow....
....with my 2004 Dodge Dakota 4x4 w/3.7L V6 "Magnum" engine?
I'm looking at renting a bobcat (6000#) and hauling it 15 miles and back.
Can I do it (truck has a tow package)?
Old Aug 29, 2011 | 04:51 PM
twitchy's Avatar
twitchy
3.7L is not a Magnum Engine, it's a PowerTech.
You could likely check your owner's manual, but I'm gonna guess it's around the ~4500# to 5000# mark.
6000# for a dakota unless the engine is larger, and the gear ratio higher... is gonna be a stretch.
Old Sep 7, 2011 | 10:29 AM
DakCC4x4's Avatar
DakCC4x4
Should be able to, just take it easy on the speed. Pulling is not so much the problem as stopping is. I pulled a small 4wd backhoe with my 97 Nissan 4wd 4cyl with no probs.
Old Sep 7, 2011 | 11:04 AM
DakMan6704's Avatar
DakMan6704
Id do it with dual axle trailer, and brakes...so long as your tounge weight is under 4-500lbs. Otherwise, have it delivered.
Honestly, heed the stopping caution...nothing like coming to a light, with or without traffic, 4 wheels screeching, and trailer just keepin on keepin on...a 4500 lb truck trying to stop ~10500lbs, isnt a good scenario...esp if you're brakes aren't in the best shape(no judgment, just a general statment).
Old Sep 7, 2011 | 12:33 PM
thunder98110's Avatar
thunder98110
powertech=what jeep calls it
magnum=what dodge calls it
