Hey Guys two things
Old Sep 1, 2011 | 10:06 PM
NickCornell's Avatar
NickCornell
Default Hey Guys two things
Alright first my buddy is gonna be able to hook me up with his 97 5.2 TB will that fit without a problem on my 03 3.9. If so is it the same sized air hat(I want my air cleaner to still fit) MOST IMPORTANTLY, will it do anything?
Second, when braking I feel I "sieze/release" up front and the steering wheel turns right a little after each seize. Warped front right rotor?
Old Sep 1, 2011 | 10:10 PM
thunder98110's Avatar
thunder98110
probably a sticky caliper.
Old Sep 1, 2011 | 10:13 PM
NickCornell
When I release the brake I don't feel anything though
Old Sep 1, 2011 | 10:15 PM
thunder98110
if a rotor is warped under breaking you will feel the pedal and steering wheel vibrate.
Old Sep 2, 2011 | 07:15 AM
bpark8824's Avatar
bpark8824
Sounds more like a seized caliber. Dakota are known for having bad calibers. If you drive around for awhile you might notice that particular wheels with more more break dust or it might even smell like something is burning if it gets hot enough.
Old Sep 2, 2011 | 08:46 AM
thunder98110
both of mine seized on me. heated up the rim so bad that the pastidip started to melt. get it fixed asap.
Old Sep 2, 2011 | 11:50 AM
Lebbie54's Avatar
Lebbie54
Binding. Simple as that. These guys hit the nail on the head so no use saying anything more.\
Old Sep 2, 2011 | 03:45 PM
dirtbiker's Avatar
dirtbiker
My TB was off a 5.9, I think it's the same as the 5.2 tb and my stock air hat fit over it fine. The v8 tb is the same size as the v6 tb, but the bores are bigger in the v8. You should probably get a new tb gasket too as long as you're gonna have it off. And yeah you can tell a difference in the upper rpms. Not so much off the line, if anything. Good luck.
Edit: Oh yeah and the exhaust has a little bit of a different tone with the v8 tb too.
Old Sep 3, 2011 | 01:36 AM
MoparMan1991's Avatar
MoparMan1991
You should just remove your air hat. It is just a worthless piece of plastic that restricts air flow. Fab up your own intake with PVC.
Old Sep 3, 2011 | 01:56 PM
NickCornell
I dont have one on, I use an eldlebrock air cleaner
