2002 Dakota SXT
Old Sep 13, 2011 | 09:46 PM
jfls45's Avatar
jfls45
Default 2002 Dakota SXT
just bought it used. it's my first Dakota. has the 3.9L V6. I bought it "as-is", 107,000 miles. I've noticed there is a sluggish, hesitating feeling when I'm at cruising speed in 4th (overdrive) at 1500 to 1800 rpm. Seems like it could have more power. I replaced the TPC sensor, no change. I did a compression check on the cylinders, this is my results:
1=180
3=150
5=180
2=180
4=120
6=125
The Haynes manual says the min psi is 100 with no greater than 40psi variation between cylinders. I did a vacuum test with good results 48psi.
My compression result for 4,6 cylinders lead me to believe there may be a blown head gasket. I am going to do a cylinder leak down test to determine.
anyone done a head gasket repair and can tell me how it went?
how about swapping the 3.9 V6 with a 4.7L V8, what all does it involve?
Any comments about my compression test?
Old Sep 13, 2011 | 10:49 PM
98DAKAZ's Avatar
98DAKAZ
Default A guess only
I don’t know the V6 or V8 but I think a blown head gasket is not the problem I think sticking piston rings or valves is more like it.
Try Gunk engine flush and then recheck the pressure again https://dodgeforum.com/forum/2nd-gen-dakota/301489-gunk-engine-flush-wow.html
Old Sep 13, 2011 | 11:04 PM
magnethead's Avatar
magnethead
Did you spin it over with the throttle blades open? We found out the hard way on the racecar, that having the butterlies closed will make a big difference on the numbers, for both leakdown and rotating compression.
That said, mine is sluggish down low, but screams at 2200+
