Wireing conversion help
Old Oct 21, 2011 | 01:40 PM
Rodester5's Avatar
Rodester5
Default Wireing conversion help
Hi all, I have to convert to orange turn signals on the rear lights, ( it seems us Brits are to dim to know a flashing red light could be a turn signal).
The book says : live to the brake light switch, one feed out of the switch to the high level stop light, a spur from this feed out to the multi-function switch, feed from the multi-function switch to the rear lights. The result is the stop light and turn signal use the same filament in the bulb, the side light uses the other filament.
I need to seperate the stop light from the turn signal, any ideas?
It's a 98 R/T
Oh, and the book says one wire in to the stop light switch and one wire out. I had a look, there seems to be 6 wires in a block connector, very confused.
