electric fan
Old Jul 28, 2005 | 02:36 AM
TexasNative's Avatar
TexasNative
Default electric fan
Has anybody ever switched out the power robbing fan clutch assembly and fan to an electric fan?????
Old Jul 29, 2005 | 12:42 AM
olsarge's Avatar
olsarge
Default RE: electric fan
I did this to my 2001 Dak. Just running the stock electrice fan. Slight noticeable improvement in accelleration. No problems yet in several days of 100*+ heat. Just barely see the temp. needle go a little higher.
Old Jul 29, 2005 | 12:55 AM
TexasNative
cool how hard was it and how much did it cost you???
Old Jul 29, 2005 | 01:25 AM
reconstrucktion's Avatar
reconstrucktion
you could also get the viper conversion kit. . . . .
Old Jul 29, 2005 | 01:59 AM
TexasNative
huh???? or r u jokin???
Old Jul 30, 2005 | 09:39 PM
reconstrucktion
no joke i belive the website is www.socaldakota.com
Old Jul 31, 2005 | 04:13 PM
Megashifter's Avatar
Megashifter
No Joke... Sam Parthemer will fix you upwith a Viper fan. Other than that... you could go the Permacool fan route. 'Bout $100. from Summit. You'll need a 55 amp relay tho. I run mine manually... it's off runnin' 40 mph or better. Both the clutch fan and the AC fas removed... no prob's in over 4 years. Permacool 14" @ 2800 CFM.
