3.9L to 5.9L engine swap PCM question
Old Nov 28, 2011 | 10:46 PM
speedfreakracing's Avatar
speedfreakracing
Default 3.9L to 5.9L engine swap PCM question
Hello all. I'm looking to swap a 5.9L in place of the 3.9L in my 2002 Dodge Dakota automatic 2wd. I'm using the stock trans with this swap. I was wondering what PCM's would work for this vehicle when doing this swap. I wasn't sure if an auto 2wd Ram PCM would work from the 2002 model year? Do I need one specific to the 2002 m/y Dakota with the 5.9L? Thanks.
Old Nov 29, 2011 | 07:55 PM
huseman808's Avatar
huseman808
Do yourself a favor and get a 5,9 Computer out of YOUR YEAR (2002) truck. I did this swap before and went through 4 different PCMs before getting it to work. -$400+ ouch
Old Dec 2, 2011 | 05:05 AM
SwampDonkey440's Avatar
SwampDonkey440
I swapped a 97 3.9 with a 99 5.9 r/t that was wrecked. Worked fine.. Older though.. Many changes
Old Dec 8, 2011 | 09:03 AM
speedfreakracing
would the PCM out of a 2002 Durango with the 5.9L work for this swap or does it have to be from a Dakota? Thanks again.
Old Dec 8, 2011 | 05:47 PM
huseman808's Avatar
huseman808
It might work, but I personally wouldnt but it unless you could try it first.
Check www.car-part.com
Its a database of scrap yards you should be able to get exactly what you need
