Transfer case shift Motor (Indexing)
Old Dec 1, 2011 | 03:32 PM
EricBing's Avatar
EricBing
Default Transfer case shift Motor (Indexing)
Just installed new shift motor on a rebuilt transfer case, NP 233, old motor went bad, upon removal shaft didn't line up, I moved it back one click, to line up with new motor, upon completion, truck doesn't want to shift into 4 low, or neutral, on selector switch... but it does try..Is it possible that shaft could be 180 degrees out of sync?? But 4 hi works and 2wd works fine, Does the shift motor have a default position upon installation?? any feedback would be appreciated
Old Dec 2, 2011 | 05:38 PM
EricBing's Avatar
EricBing
Well all removed shift motor again, moved ot back 2 where it was at moved motor 20 degress to line up turns out it was other neutral, re-installed hooked up turned on key it moved back WTF?? still wont engage in 4-lo.......Lost at this point thinkin of takin it back to ppl who rebuilt xfer case, but dont wanna,,, any help??
Old Jun 10, 2012 | 08:25 AM
EricBing's Avatar
EricBing
been awhile.. found the problem here LOL.. one of pins on 6 pin connector bent over, tricky lil bugger in a hard to reach area, with no visibility, getting quite good at pullin t-cases tho
