Leaf spring clamp install
Old Dec 22, 2011 | 03:29 PM
thunder98110's Avatar
thunder98110
Default Leaf spring clamp install
On my quest to gain better traction i found that leafspring clamps can help quite a bit for wheel hop/tire spin. Found these on amazon for less than $30 bucks and takes about 15min to install. By replacing the front and removing the rear it will supposedly help with weight transfer.
tools needed:
Start to pry the tab off on the bottom.
Almost off.
Stock vs. Aftermarket
Line it up.
Tighten down. You can see the difference in the stock and new ones in the way the spring is compressed.
Old Dec 24, 2011 | 01:35 AM
Blaze10's Avatar
Blaze10
nice wow, does it effect height? because on my 99 dakota those stock ones rusted off mine lol
Old Dec 24, 2011 | 01:37 AM
thunder98110
no change in height. i cant tell difference yet b.c its been so cold and the tires never warm up they spin pretty bad anyways.
