Broken rear caliper piston - Next steps?
Old Dec 23, 2011 | 09:30 PM
csamson's Avatar
csamson
Default Broken rear caliper piston - Next steps?
I’m replacing the rear rotor and pads on an 03 Dakota Quad cab, 4x4. I got everything apart and the rotor in place. However, I put the inboard pad in upside down, and in doing so I took a wedge out of the caliper piston. The wedge is ~1in wide and 3/8” deep. No fluid leak as of yet, but the piston is pushed all the way in, in preparation for putting in the new pads. I’m not sure if it will start leaking once it extends.
As I see it I have two options, replace the caliper or replace the piston and boot. I’m assuming the former is easier than the latter. As you can tell, I’m no mechanic. Do I have to buy two calipers? The book indicates replacing them in pairs. Anything I should watch out for when replacing the caliper (other than myself).
Thanks.
Old Dec 23, 2011 | 09:31 PM
thunder98110's Avatar
thunder98110
i didint think Dakotas had rear calipers, i thought it was always drums.
Old Dec 23, 2011 | 10:01 PM
Xxaler's Avatar
Xxaler
I'm not sure what you're talking about a wedge 1" deep and 3/8" wide? Please elaborate..
You don't have to replace your calipers in pairs, but it is recommended to keep even braking power on both sides. If you just put in new pads and rotors on both sides, I honestly wouldn't even worry about it.
If you've messed up to the point of actually needing a new caliper, don't just order the caliper. Check the price for the full assembly, depends on vehicle but sometimes they charge $220 for the caliper alone, then $90 for the full assembly (caliper, anchor, hardware as a kit). Slap a vice grip on the flex hose lightly, unbolt the hose from the caliper, get your two copper washers on there, then slap it onto the new caliper, gravity bleed, then pressure bleed.
Old Dec 23, 2011 | 10:25 PM
01SilverCC's Avatar
01SilverCC
I cracked the piston on one of my brake calipers about 2 years ago. I had used a big pair of Channellocks to bottom the piston back into its bore, instead of using a c-clamp. I was in a hurry and should have slowed down and used a c-clamp. It took a small chunk out of the edge of the piston and put a long crack in it too. It might have been OK to leave it that way but to be on the safe side I just replaced both calipers. I think I spent $80.00 or $90.00 on the pair. If I were you I would replace both rear calipers and bleed the brakes after that.
Jimmy
Old Dec 24, 2011 | 02:48 PM
98DAKAZ's Avatar
98DAKAZ
Default one is ok
You can only replace only one caliper if needed as long as the other old one is in good shape.
I have done it a few times on the front of my truck with no problems only replace one caliper.
Old Dec 25, 2011 | 06:53 PM
csamson's Avatar
csamson
Default Thanks
Thanks all. The wedge was a chunk of the piston that popped out. I got a replacement caliper and will install it tomorrow. I appreciate the help/advice.
