02 3.9L - Big Effin' Coolant Leak
Old Jan 5, 2012 | 05:39 PM
sxrsil3nt's Avatar
sxrsil3nt
Default 02 3.9L - Big Effin' Coolant Leak
Truck has developed a MAJOR coolant leak. Only 49,000 kms.
I'm thinking its the upper hose cause I can see coolant dripping from the clamp but there is also coolant dripping from the bottom left bolt holding the water pump in - but I'm not sure if thats just leaking down from somewhere and running off.
Are there any common spots related to coolant leaks? Coolant is everywhere I can't really narrow it down.
I'm hoping its not the water pump, I don't think it is because the truck isn't overheating.
Right now the truck is not drivable.
The truck leaked probably close to an 1-2 fl oz. in about 5 mins.
Not good.
Old Jan 5, 2012 | 05:58 PM
BlueQC's Avatar
BlueQC
try to wipe the the coolant off and then make sure rad is full then start engine and have a look! if it is a hose it is 15 mins work to swap the hose out. If it is the pump it should be coming out the weep hole on the pump.
Old Jan 5, 2012 | 06:40 PM
sxrsil3nt's Avatar
sxrsil3nt
That's just it - its leaking from everywhere.
I just crawled under and loosened the clamp and pushed the hose up as far is it could go and then added a second clamp just behind the one that was on there. It leaked a ton while I did this and when I started it up coolant was still dripping this time on both clamps.
I can't see the weephole because there's the other pulley directly below the water pump pulley (don't know what that one is).
It's a huge freaking mess under there right now and like I said it cant be driven. It had a small leak 2 days ago and now its huge.
Old Jan 5, 2012 | 08:20 PM
sxrsil3nt's Avatar
sxrsil3nt
I'm just going to bring it to a shop.
I've had too many problems with this truck too soon and I'm fed up.
